| | | Forums66 Topics128,139 Posts1,056,448 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 5 New Guy | | New Guy Joined: Aug 2011 Posts: 5 | I am replacing the rear wheel bearings in my 63 C10. My friend was too heavy handed in using his slide hammer to extract the old bearings and seals. Both wheel bearing retainers were bent and knicked badly. So much, I don't think they are usable.
Does anyone have a source for these retainers. They do not come with the replacement bearing and are not a part that is stocked by any of the parts houses.
I have tried junkyard dog and other places, but none available or no response.
Any suggestions would be appreciated. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I cant place what you mean by retainers. Do yoy have the type with the C washers in the rear end or are the bearings pressed on the axle? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2011 Posts: 5 New Guy | | New Guy Joined: Aug 2011 Posts: 5 | C-clips hold the axles in. The wheel bearing retainer is a machine bushing....2.53 OD; 1.625 ID and 16 ga thick that goes behind the bearing. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I gotcha now. It seems it is a spacer. You ought to be able to straighten them & grind out the nicks. Lets see what some of the other bolters think. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2011 Posts: 5 New Guy | | New Guy Joined: Aug 2011 Posts: 5 | Thought I would close this out. Best thing to do would be to use a press to straighten the retainer and then grind out any burrs. But one of the retainers was lost. I used some standard machine bushings, 2.5 in OD x 1.75 in ID x 14 ga. Was a little smaller OD (0.03 in) and larger diameter hole (1/8 in) and a little thicker (14 ga vs 16 ga). But the axles and c-clips, bearings and seals all went in just fine. The bushing has enough lip to grab when removing the bearing next time, so all is fine. Thanks
