1 members (baldeagle),
118
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77535 05/13/2007 2:11 AM | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | I have a 1954 chevy 1/2 ton with a 235. It runs great, but at idle it seems to miss every once in awhile. It will idle great and then just for a second run rough. Could this be timing? It has new plugs and points. How do I tune it if mine doesnt have the marks? What could help. Thanks in advance! | | |
#77536 05/13/2007 3:01 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | old54truckluvr,
I would think more carburetion, maybe a improper float setting. At an idle, not much is going on with the mechanics of the engine other than the carburetor.
Stuart | | |
#77537 05/13/2007 5:53 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'm curious as to why your '54 doesn't have timing marks. The "BB" should be visible through the hole in the bellhousing above the starter. It is possible to get the timing off so far that the mark is not visible.
As has been stated here before, the ultimate timing for your engine is to advance it as far as you can (in small increments) until you get a slight pinging on heavy load, then back it off until the pinging just disappears.
Recheck your points first though, new points will "wear in" quickly and need to be re-checked. | | |
