| | | Forums66 Topics128,260 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77529 05/12/2007 10:39 PM | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Well, I pray that I've done everything right. Finished the cam break in (I hope!) and added a little more transmission fluid to the TH350. It drove back into the shop, though it did seem to take more throttle than I'm used to on an automatic. Perhaps because it still needs a couple of qts. of tranny fluid? I'm used to putting truck in gear and it moving at idle. Have to give it gas. At any rate my 56 TF does move and run. Now to fix all the miscellaneous leaks and stuff. Then on to the final cosmetics. Any thoughts on the tranny would be welcome. BTW, it is a fresh rebuild from O'Reilly's also. | | |
#77530 05/14/2007 1:04 AM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Congrads Clint. Keep us updated and send more pictures.
~Jim
