1 members (Millenimech),
118
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 9 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 9 | Have a project coming in this weekend and am ready to get some stuff to get started! Delivery is set for sunday. 1.Would like to change the brakes to disc. 2.New Brake Lines 3. Wheel cylinders etc
It runs I am told but will not stop. Will be using on a everyday basis so reliability is a must. Any help is appreciated!!
I have looked at the parts companies but everything is for 1 ton or less.
1949 Chevrolet 4400 Frame up project to be completed in less than 6 months. (and counting)
| | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | JIm Carter should have most everything you will need for your 1.5 ton. some engine stuff is the same as 1 ton or less so classic truck is always as option. Hope it helps.
1949 Chevy 4400 216
| | | | | Joined: Aug 2011 Posts: 9 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 9 | Thanks! I have begun the cleanup! Hope to get some pix up soon.
