2 members (Peggy M, treegrower), 226 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
#775129 08/26/2011 4:34 AM
When replacing the master cylinder on a truck with a hydrovac, do all the brake lines need bled or just the line from the master cylinder to the hydrovac?
Big Bolt Forum Co-moderator
According to the manual (you can see it online at http://chevy.oldcarmanualproject.com/shop/1954truck/index.html) if you work on the hydrovac, you need to bleed the entire system. I sure would anyhow. Basically you are adding air to a closed system.
1948 Chevy 2-Ton
Thanks! I have an experienced GMC mechanic that will be doing most of the work, but wanted to know just what to expect.
Once you bench bleed the new master cylinder you would normally need to bleed only thru the hydro vac, really shouldn't need to bleed all wheels, but it wouldn't hurt to do that as you'll get new clean fluid throughout.
