3 members (Otto Skorzeny, Reftys49, FAST55), 143 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#774999 08/25/2011 9:07 PM
I have a 64 c10 and want to identify for sure the engine size currently in the truck.
An old hot rod builder said it did not come with a 230 straight 6 and the guy I bought it from says that is what it is.
The numbers that are CAST into the block are 3994257 with a large GM under that and a 65 under that
The numbers stamped into a plate just behind the distributer are, as best as I can make them out 1101C3J and some numbers under that and I can't make those out.
So any idea what motor this is?
On the body is 4C144S189609 but that number means nothing since I do not know if this motor is original to the truck.
Thanks as always,
Scott
The block #'s show a 67-72 250
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
On the Pad near the Distributor, the last 3 should be all Letters. It looks like the engine is a 1970 or newer as that is when GM went to 3 Letters instead of 2. The first Letter of the 3 "C" tells us that it is an engine from a Car.
Like Jon has mentioned, it looks like it is a 250.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Okay I looked closer and the 3 is actually a B
1101CBJ and the number under it is 12W198828
250, originally passenger car (at least Chevelle/El Camino, possibly Camaro or Nova as well) with the Powerglide. It's at least a '72, that's the only year that code is listed in my book, which stops at '72.
Bill Burmeister
Okay then.
Thanks very much for the help.
Sure glad I found this site.
I live in a small town and it is very hard to find information on anything around this town.
Appreciate the help...
scott
By the way, the "1101" is November 1st.
The number under it that you have listed is the car's VIN Number.
GMC 9500 Fan
Detroit Diesel Fan
The internet is an amazing thing, regardless of where you live.
Originally Posted by AzMcCoy
Okay then.
scott
