| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Maybe this site may help you. One problem it states is that prior to 1990 tire manufacturers weren't required to put what decade a tire was produced so it may be impossible for you to determine exactly when the tire was made. So your tire example may have been produced in the 20th week of the first decade, but it can't be determined by the attached site as to what decade. 50s, 60s, or ??? But, since it is a SEARS Allstate Brand, I would guess, only a guess, mind you, that they are from the 60s as I would think a 1950 tire would have deteriorated too much. http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
Drew
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I would think it to be the 20th week of 1961 because the 20th week of 1951 would have still been a rayon tire instead of nylon. By 1971 the wide whitewall was no longer available. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Are you going to drive to the event, or trailer the truck? I don't think I'd trust tires that old to run very far, especially in the summertime temperatures most of us are experiencing right now. If you're just unloading/reloading on a trailer, or making a SHORT low-speed run to the show, go for it. Just don't bet your life on those tires at highway speed. Jerry
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | The thread here at the AACA says that Allstate tires were sold up to the late 80's / early 90's. The thread here at the HAMB backs that up as well. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Sears did market Allstate for quite a long time after these tires were built, but not 6.50x16 nylon with a wide white walls. Narrow white walls became popular in the mid 60's and nylon tires did not appear until the early 50's.
This is an article from Time Magazine that was printed in 1961. I was driving nylon tires by then and I would have more faith in a 50 year old nylon tire than a 20 year old steel radial.
http://www.time.com/time/magazine/article/0,9171,894541,00.html | | |
