1 members (2-Ton),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | Spanky im looking to replace the widow makers on my 66 c/60 with eather alcoa wheels or regular tubless steel wheels. any suggestions? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Check with Grigg. He's done alot more wheel research than i have. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | First tell us what bolt pattern you have, how many studs on what bolt circle? Then you as well as I can check the Accuride catalog for new steel wheels. Aluminum may be difficult to find. http://www.accuridewheels.com/completeversion.pdfGrigg | | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Grigg -- Looks like 10/5 from his pictures.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Steel is the only option, they're in the catalog, 22.5" tubeless. Page 12 part number 28160
Can also be found used if you look hard, not rare but not extremely common either.
Grigg | | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | thanks for the help fellas! gonna see about placing my order this after noon! | | |
