7 members (TUTS 59, MNSmith, RLB, carbking, tclederman, Wayne67vert, 1 invisible),
120
Mod | | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Hello, all -
I'm going to replace the oil lines and fittings to the 235's oil filter. I believe the fittings are 1/8" NPT. How should I prep the fittings at the motor? I'm guessing I don't use PTFE tape. And, I'm assuming they don't go in naked.
If I were to get these lines pre-assembled, does anyone have a good source? Doing a "quick" search, I've only found them at American Classic Truck Parts for something like $35 a set.
Thanks!
1956 Chevy 3600 Dually
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | I like the brush-on teflon pipe dope. It's less likely to get into places it's not needed, like inside an oil passage, than the tape. Just brush a thin layer onto the threads, leaving a couple of threads near the end of the fitting uncoated. Teflon tape in an oil pump relief valve or a rod bearing can cause some pretty nasty problems. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And as everyone has an opinion I do also, mine is Permatex 3H Aviation Gasket sealer. Use it on all my engine related fittings where I want to seal the threads, gas, oil or water, yet be able to get it apart down the line. No worry about getting anything in the gas, oil or water systems and pluging up a passage. But as I said everyone has their favorite.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Thanks for the info, guys. And the links; I even searched some of those vendors before I posted. Not enough coffee before surfing, I guess!
I believe I was overly concerned about the engine bay environment's affects on tape/dope/goop at first and wanted to make sure I wasn't doing anything damaging.
