| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | Here's a picture of the rear axle. The poor man's lowering job by the PO. They put the axle on top of the springs and put 14" donut tires in back. No C-notch, so I'm going to flip it back where it belongs. http://i12.photobucket.com/albums/a205/gvdobler/0810011615.jpgYou can see by the picture, all is rusty. How much is too much. I'm lost with where to begin. Can you take parts to have them blasted or is that a big (too much) expense. Thanks
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What I see is just surface rust and of no importance except looks. You decide what kind of ride it will be. If you want it to be a quality look you might want to have it blasted to remove not just the rust on the running gear but the sheet metal. Then you'll see just what you have and how much meaningful rust is there.
~Jim
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | That doesn't look bad at all! Take a wire wheel to it and you'll see that it is just lightly pitted. Take a look at my running gear before and after. It was worse than yours and it is perfectly fine today. Before after I wire wheeled everything, but blasting would have been much easier! Sprayed epoxy primer then Chassis Black topcoat. | | | | | Joined: Mar 2009 Posts: 19 New Guy | | New Guy Joined: Mar 2009 Posts: 19 | Older post but I was in the same position as you, just take your time and run through it one section at a time...I wire wheeled it all also..Por15 Then hardnose paint... Before After I bet you like my stand there ha... Good Luck tho..
I never let the truth get in the way of a good yarn..
| | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | I like how you held the frame off the gargage floor 58Duluxe
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
