4 members (Guitplayer, MickeyP, Ponchogl, ShopRag), 90 guests, and 1 robot.
Topics128,035
Posts1,055,564
#770782 08/12/2011 2:29 AM
Here's a picture of the rear axle. The poor man's lowering job by the PO. They put the axle on top of the springs and put 14" donut tires in back. No C-notch, so I'm going to flip it back where it belongs.
http://i12.photobucket.com/albums/a205/gvdobler/0810011615.jpg
You can see by the picture, all is rusty. How much is too much. I'm lost with where to begin. Can you take parts to have them blasted or is that a big (too much) expense.
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
What I see is just surface rust and of no importance except looks.
You decide what kind of ride it will be. If you want it to be a quality look you might want to have it blasted to remove not just the rust on the running gear but the sheet metal. Then you'll see just what you have and how much meaningful rust is there.
~Jim
That doesn't look bad at all! Take a wire wheel to it and you'll see that it is just lightly pitted. Take a look at my running gear before and after. It was worse than yours and it is perfectly fine today.
Before
after
I wire wheeled everything, but blasting would have been much easier! Sprayed epoxy primer then Chassis Black topcoat.
Older post but I was in the same position as you, just take your time and run through it one section at a time...I wire wheeled it all also..Por15 Then hardnose paint...
Before
After
I bet you like my stand there ha... Good Luck tho..
I never let the truth get in the way of a good yarn..
I like how you held the frame off the gargage floor 58Duluxe grin
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
