0 members (), 90 guests, and 1 robot.
Topics128,055
Posts1,055,782
#77060 05/03/2007 1:57 PM
I just had a quick question regarding the removal of the pilot bearing on this 283 for my '66 Fleetside. Do I have to buy a special tool for this. Everyone says to change it as a matter of course before I put the motor back in.
Any ideas here?
GWS
GS
#77061 05/03/2007 2:45 PM
pump some grease into it and hammer a pilotshaft in to remove it 'hydraulicly', usually they come out pretty easy
#77062 05/03/2007 2:45 PM
There is a special puller you can buy for pilot bearings, costs about $25 at harbor freight. If the pilot bearing is a solid one (not a ball bearing) you can pack the bearing hole with grease and then get a round piece of steel or bolt that will just go into the pilot hole and pound on it with a hammeer. The grease acts as a hydraulic media and will push out the bearing.
#77063 05/03/2007 5:05 PM
If you run into one that will not come out with the mechanical puller or "grease" method I've found that using a center punch to mark a spot and a 1/8 drill bit will relieve enough tension so that it can be mechanically removed.
The key to getting it out with grease is to pack it full....I use a 5/8 wooden dowel trimmed down to fit tight in the bore and smack it SMARTLY with a 3 pound+ hammer. I have a good pilot brg puller and it doesn't always work. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#77064 05/03/2007 5:25 PM
Thanks a lot. I will do this. I appreciate the feedback.
GS
#77066 05/04/2007 12:01 AM
The easiest way of all is to buy a tap large enough to grab the bearing and just turn it into the bearing with a wrench until it bottoms out on the crank shaft flange, then continue to turn it until it runs up the tap and comes totally out. No messy grease, no toilet paper (that's one I haven't seen before), just a mechanical extraction solution.
Joe smile
#77068 05/04/2007 12:25 AM
Don't break the tap off, though, then you are SOL.
Playdoh works better than grease and is easier to clean up.
Paint & Body Shop moderator
#77069 05/04/2007 12:46 AM
Lisle tools sells a handy looking tapered screw that bites in to the bushing, then you put a grease gun on it to force it out. I think I will get one one day. Could be a little less messy than the grease and hammer, and perhaps quicker.
I have had good luck with the tap, but once you have threads in the bushing remove the tap and use a bolt to jack the bushing out. Or a slide hammer on the bolt.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#77070 05/04/2007 5:32 AM
Grigg -
That'll work, too! Then there is no worry about poppin' the tap.
Joe smile
#77071 05/05/2007 2:19 AM
An ordinary bolt has worked for me just as well as a tap.
Harold Wilson
41 Chevy 3/4 Ton
