0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | Greetings, just aquired a 53 GMC 3800 fire truck pumper with VIN # 353 22 C 1404, 8800 GVW. I can find 24 C but havent seen the 22 C designation. Any input? thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Welcome to Stovebolt.com http://www.oldgmctrucks.com/page0010.html353 22 C 1404 353 = 350 series (2 ton) 157" wheelbase (the 3 at the end of 353) 22 = 228 engine C = Oakland, CA assembly plant 1404 = production sequence number (starting with 1001) = 404th truck of that series off the line I am not good at decoding GMC codes, someone will correct the above information, if any of it is wrong. You might want to also join the oldGMCtrucks.com discussion boards. | | |
