0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#76959 05/01/2007 5:56 AM
Apprentice
Apprentice
Bought my truck 1950 GMC 100 last month and it has a 228. It has idled and ran rough. I have noticed a pipe about the size of a straw coming from the rear of the intake manifold closest to the firewall. The pipe is open at the end. I searched this site and came to the conclusion it is from the vacuum line for the wipers (which have been coverted to electric). When I plug the top of the hollow tube with my finger the engine runs smoother. Am I correct about this being a vacuum line? Should it be capped some how? What should I do with it?
Smittster,
It sounds like you have diagnosed the problem perfectly. I have plugged vacuum lines with rubber caps made just for that purpose..usually available from a hardware store or auto supply store. The only caveat would be launching the little plug into orbit if the engine backfires.
This might be what happened to the previous rubber cap. Threading a small machine screw into the hole would offer more bullet proof results.
Stuart
I usually run a short length of hose to a bolt, then put a hose clamp around the bolt. Select a size that won't get inhaled, and the clamp will keep it from leaving.
Otherwise use a pipe plug in the manifold hole.
Paint & Body Shop moderator
