1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I bought my truck with a slight knock that sounded like it was in the valves. I expected to find a couple of valves that needed adjustment. I actually found one valve that has a huge gap and when I turn the pushrod I see it has a pretty good bend in it.
Do I just readjust the valve? Do I take it apart and try to straighten? Or should I replace the pushrod?
The engine is running great.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | I would look at all the push rods and make sure none of the others are bent. It is easy to bend a push rod it the valves were adjusted wrong with solid lifter. If they are bent replace them __________________________________________________ 37 Chevy 1/2 ton
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | I'd order a new pushrod (they're pretty cheap) and straighten the old one to use until the new one arrives. Or, just wait a few days and you'll only need to adjust the valves once, when the new one comes in.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Great, so I can just replace the bent ones and leave the rest. I guess I will pull the whole rocker assemly off to clean it as well, it looks pretty cruddy up there. Where to order them and are there different ones?
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You should be able to get them through a local parts store, the mom & pop operation. If not, try one of the on-line vendors, I think Patricks has them. When you clean your rocker assembly, mark everything so you can put it back the way it came apart. I made some thin aluminum tags, I saw the other day one marked with a paint marker, which held up under a solvent bath. Check all of your pushrods for straightness, you might find more that are bent.
Fred 52 3600 69 C-10
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Tony....push rods don't just bend on their own.... Please see if you can find why it did before you have major problems | | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | you also might want to check the piston in that cylinder. Something might be in the cylinder that made the rod bend, and it could have caused damage to the piston, like a puncture. to check for bends in your other pushrods, just roll them on a flat surface like a table and see if the ends come up as you roll them along.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#7700 03/25/2002 11:31 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I have seen the bent pushrod thing in 235/261 engines before.One time it was a valve sticking in the guide that caused the pushrod to bend.Another time the failure appeared to caused by lack of oil to the head, the push rod was blue at the end.Check the ball on the end of the rocker adjustment screw.Does it look like a teat with a nipple or is it still round and smooth like a new one??Does the rocker tip that contacts the valve have a deep groove worn onto it? Unexplained bent pushrods usually go with the worn rocker arm parts.I think piston to valve interference on a stock engine is unlikely .As Jim says, they dont bend on their own.Your local machine shop will carry replacement rods or Patricks has nice tubular ones for the same money as stock forged ones. | | |
