2 members (Peggy M, Bill Hanlon), 192 guests, and 3 robots.
Topics128,089
Posts1,056,116
Members48,434
#768986 08/06/2011 10:27 AM
I am looking at repowering my '47 1.5 ton truck.
Is there a "better" hi pressure 235? Or were they all the same 55-62?
Was there any head that was better? Were some hydraulic and some solid lifter?
One local option is the Holden 202, although it wont bolt straight in. These were developed in Australia by Holden, from the original 250 Chev L6 in 1963. By 1980 they were well refined, that year they got a 12 port head, in '82, fuel injection. The "black" motor.
http://en.wikipedia.org/wiki/Holden_straight-six_motor
cheers
'47 Canadian RHD 1.5 ton truck
Regarding your question about a better or best 235, if you are looking for horse power differences this chart might help.
The information on the four pages in that stovebolt engine information is for USA stovebolt engines.
This information is found at the bottom of the Casting Numbers page:
- All truck 235s and 261s had mechanical lifters.
- From 1956 onwards, all car 235s had hydraulic lifters.
- From 1950-1955 all car 235s in cars equipped with the Powerglide transmission had hydraulic lifters (except for the 53-55 Corvette's 235, which had a Powerglide transmission and mechanical lifters - it also used the 261 cam, which had a slightly modified lift).
From 1956 onwards, 235s had a higher compression head (casting code 3836848), which improved performance. Also, I think that the 261 cam was also used in later 235s (1956 and later truck 235s, maybe) but I am not sure about this.
Got any 1955-1962 Canadian built Pontiacs out your way? The best 235 is a 261 and you can learn about them here:
http://www.97330.com/Chevy_261/261_6.html
You Tube
A 54 235 or 261 would be the easiest swap since you wont have to deal with the water pump issues.
