2 members (Otto Skorzeny, Hotrod Lincoln), 68 guests, and 1 robot.
Topics128,052
Posts1,055,717
#76907 04/30/2007 9:36 PM
Apprentice
Apprentice
I have been told a number of times that the 235 head, serial number 848 is a better selection for the 261 engine, because of higher compression. Are there any pitfalls with this match up, anything that I should be aware of. I found a 848 head and I have a 261 block and crank.
#76908 04/30/2007 9:46 PM
There are some extra holes in the 261 block between the cylinder bores. These need to be added to the 235 head to allow for proper cooling.
Paint & Body Shop moderator
#76909 05/06/2007 2:01 PM
The 850 head is the 848 for 261s.
If you use a 848 head you'll have to drill the two holes for the steam vents.
#76910 05/06/2007 2:23 PM
51flatbedchev,
You will have to drill 2 holes per pair of cylinders - 6 holes total. You can use the 261 head gasket as a drilling template.
Photo of the additional coolant holes/passages from Jim Carter\'s site.
If you are interested, here is a cut-away diagram of the cooling holes and passages.
Tim
#76911 05/07/2007 7:20 AM
The 850 and 848 head have the same port sizes, combustion chamber shape, and valve size. The 850 just has more meat to lower the compresion on the 261. Don't expect any more flow out of the 848 head, all you are going to get is a smidge more compression, which makes a bit more torque.
#76912 05/07/2007 9:16 PM
Here is a picture of my 848 head that has had the coolant holes drilled for a 261 block. There are three pairs of holes, hope this helps you out.
848 head coolant holes drilled for a 261 block
1951 3100 Chevrolet
