6 members (66flea, moparguy, ronsway, TUTS 59, 1955 1 Series, 1 invisible), 347 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
Since I've had my 51 truck back on rode I get foaming anitfreeze out of overflow tube on the ground when I stop. The back of my cap is gunky looking also.
What do I need to do?
Find out where your leaking oil into the coolant. If your seeing a kind of brown frothy looking goo in the coolant then you will probably be seeing the same thing in the oil. I'd look for a leaky head gasket first off.
DG
Denny G
Sandwich, IL
thank you!
Jack of all trades and a Master of None!
You can also have a leaking head gasket into the combustion chamber, are you losing coolant? Pull the the plugs and look for a burnt "white" coloring on it. Coolant in the combustion chambers would yield white smoke from the exhaust, as well as a "sweet" smell due to the antifreeze being burned off. You may also experience loss of power and coolant loss depending on the severity of the head gaskets condition. Another thing you can do is have it checked on a scope, by a mechanic, for really HIGH hydrocarbon emissions.
My57Suburban
This is the slickest swap I have seen for trucks
EZChassisSwap.com
