| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76852 04/29/2007 1:39 AM | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I have a 1946 1/2 ton truck. I installed a 1957 235 bolted to the 1946 bell housing and the Buffalo adapter plate for the T-5. I want to use the 168 tooth flywheel and 12 volt starter.
What pressure plate do I need? Will the Advance Design pressure plate work in the Art Deco bell housing with out mechanical problems with the fork and pedal linkage? I will be using the Buffalo adapter plate and a T-5.
Thanks 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | |
#76853 04/30/2007 1:29 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I believe you should mbe able to use any pressure plate you want in there... that will bolt up to the flywheel that is. I am using a 59 gmc flywheel on my 302 gmc that will be going in my 1940. I will be using an 11 inch clutch with 10 spline 1 1/8 inch diameter hub... same as stock, for 1959.
To sum that up, I will be using an 11 inch clutch in a bellhousing that originally ran a 9 inch clutch. Allthe linkage will be stock. | | |
#76854 04/30/2007 5:00 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | 46SortaStock - I'm sorry I didn't have a quick answer for you Saturday when you called. After thinking your question through and getting back to my computer, I agree with bigbadswingdaddy. I think any pressure plate that will bolt to the 168 tooth flywheel will have enough clearence inside the 46 bell housing with stock clutch linkage for all of the mechanics to function properly. I know a 9" and 10" (9 7/8") clutch and pressure plate combination will work in your bell housing with the S-10 T-5 transmission and I'm sure you can get an 11" (10 3/4") clutch and pressure plate to fit that 168 tooth flywheel. Steppenwood used that clutch pressure plate combination on his 41 pickup with success. I feel confident that any size you decide to use on the 168 tooth flywheel will have the clearence necessary for everything to function properly. Hope I got this information to you quick enough to help! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#76855 04/30/2007 5:03 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need a clutch disc from an Astro van to match the T-5 splines. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#76856 05/01/2007 5:27 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | D1ck - The Astro 10" (9 7/8") clutch is the one I used. Steppenwood used an 11" clutch on his 41, but I don't know what that clutch fits. The Astro common part number is RCF 4201. I have found out that NAPA (at least the one in Saginaw) will not sell the clutch by itself. They want you to buy the clutch, throw out bearing, pressure plate and guide as a kit. Standard Transmission in Fort Worth will sell the clutch by itself. Steppenwood used the RCF 4212. I'm sure NAPA will handle that the same way, but Standard will have it. Standard will need a few days to get either clutch. Let me know if you need more info. Joe
#76857 05/01/2007 7:27 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I stuffed an 11" HD 261 clutch into a '50 216 bellhousing, and it barely clears but it fits. I had to use a shorter throwout bearing and it works fine. However, the 13" clutch that came with my 302 is never going to fit, it is sized to fit a clark bell housing. I'm going to have to find a smaller flywheel for it.
#76858 05/02/2007 2:17 AM | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I had one vote from another source that it would not fit. I looked at steppenwood's site and he is using a 11" RFC4212 in the 45 bell housing. I did not see in the pictures and diary what brand or part number pressure plate he used. I will send him a PM or email.
Thanks to everyone for the responses!
D1ck 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | |
