3 members (Jon G, Guitplayer, Wally / Montana), 123 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
Hi there,
I have a 54 Chevy Truck that I thought was converted to 12V. I have been working to get this running for 2 years now and I am running out of options due to my very limited mechanical knowledge.
I have gotten no spark from the engine, though it turns...at least it did before I swapped out a Pertronix coil and point. It then stopped turning on teh 3rd try.
Could it be that the system was not fully converted, and my bigger question is how can I tell? The parts I know for sure are 12V are the battery, started, generator, and coil. What else needs to be converted? How can I tell if it has been?!
I appreciate the help. I want to see this thing through!
Carlos
Most of the Delco regulators have "6 volts" or "12 volts" stamped on the regulator housing right by the part number. I don't understand why you keep blaming the regulator for the engine failing to turn, however. The only thing it does is prevents the generator from overcharging the battery once the engine is running. An engine will run with no generator, regulator, fan belt, or even if it's missing the water pump, it will run for a short time before it overheats. If you hand crank it, you don't even need a starter.
First, as has been suggested to you repeatedly, turn the crankshaft by hand, or put the truck in gear and push it a little, (gently, don't force it) to determine if the engine is locked up or not. Assuming it will turn without getting into a severe bind, find out why the starter is failing to turn it. There's only two possibilities there- - - -lack of battery current, or internal troubles in the starter. Stop trying to blame everything in sight and running off in all directions. Attack one symptom, and only one, and follow it until you find the cause of the problem. If you're not able to do that, find someone who can think logically and methodically, who also understands how engines and electrical systems work, pay him well, then watch and learn as he/she finds the cause of the problem.
Thanks for the advice. Truth is I am baffled and will likely call an expert to figure this one out.
