| | | Forums66 Topics128,180 Posts1,057,154 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | Just wondering how to check play and when to replace the bushings on kingpins. I have a slight play in the front one on the left side (everything is off but the spindle) I'm cleaning all the grease and grime off the kingpins/axle as I'm doing the brakes. Just curious. Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should have no play in them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | You should have no play in them. Really? Seems like most suspension things like ball joints, etc.. have a small amount of play. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | You should be able to turn the spindle with your hand, but should have no wiggle at all from side to side.
Jeff | | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | You should be able to turn the spindle with your hand, but should have no wiggle at all from side to side.
Jeff I have a small amount of play. Maybe a millimeter or so. How hard is it to fix? I have an ancient set of kingpin reamers from an estate sale. Cornwell brand I believe. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its true there shoould no play in them. It depends on how picky you want to be & what you are going to do with the truck weather you should replace it or not. Basicly they are pretty easy to replace but you can run into problems. Sometimes the kingpin is stuck in the axle & can be a nightmare to get out. Then its possible the axle is scored & the new kingpin fits loose in it. Then you have to ream it out & use an oversize kingpin set. I dont mind working on any part of these old trucks but the kingpins scare me. You probably have floating bushings in yours so the bushings will not have to be reamed. Hang on to those reamers. You cant buy them anymore. Some of the older cars had load carying ball joints with a certain allowance for play, But other then that no steering component should have any looseness. Like tie rod ends or drag link ends. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | What do you guys think about using an adjustable reamer when doing kingpins? Thanks Don | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have a half ton, your bushings will not need to be reamed. A 1 Ton has pressed in bushings that have to be reamed. If you have everything off the front except the spindles, I would definitely replace the kingpins. If you get stuck, just take the axle off and take it to a shop. | | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | So I don't have to ream the axle for the new kingpin bushing? It's a 3200 1/2 ton. Here's the set I was talking about, [IMG] http://i51.tinypic.com/xo1pb7.jpg[/IMG] Truth is I don't know if it's in fact a kingpin reamer kit since it's so old I can't find info online for it. I'm assuming though. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You do not need to ream the 1/2 ton truck's king pin bushings (an upper bushing and a lower bushing) that reside in each of the steering knuckles.
The king pin also passes through the axle. If there is very little (or no) movement of the king pin in the hole in the axle, you will not have to ream the axle to fit a an over-sized king pin.
| | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | You do not need to ream the 1/2 ton truck's king pin bushings (an upper bushing and a lower bushing) that reside in each of the steering knuckles.
The king pin also passes through the axle. If there is very little (or no) movement of the king pin in the hole in the axle, you will not have to ream the axle to fit a an over-sized king pin. Okay let me get this straight. The bushings upper/lower are in the knuckle which has the spindle on it correct? I can just knock these out and install new ones and I should be good to go as long as the king pin isn't sloppy? I have a drop axle in the backyard maybe I could practice on that one first.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used these instructions from the tech tip section of this fourm. I purchased the replacement kingpins from my local auto parts store for my 3100. The kits come with pins, bushings, and shims if needed. You will have to search for correct part number for your year truck. | | |
