1 members (crenwelge),
151
Mod | | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Does anyone know if the chrome ash tray knob designed for 47-53 trucks will work with a 1940? I guess as long as the holes are the same size and in the same spot? I was going to order the rose tan replacement for 40-46, but I think the chrome would look better.
1940 Chevy 1/2 ton, 12 volt, 350/350th
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used the rose tan on mine to match the window cranks. I think chrome would look fine as well - it is kinda tucked down under the dash so you don't see it a lot. | | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | If you look in the catalogs, the knob is a different part completely. I thought maybe the mounting posts would be in the same positions, because maybe the ash trays were the same? I'm hoping that's the case because I'd rather use the chrome.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the ashtrays are totally different - this is the later oneBill | | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Oh yeah they are, huh. Then I guess GM would have had no reason to make the knobs interchangable, since they changed the ash tray design anyway. I'd order one anyway, just to try it but lately everything I've been ordering on a hunch that it might fit has turned out to be a waste of time and money. I guess I could get the tan rose one and just paint it black. The chrome would have looked so cool though.
