Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Rich'sToys, Hotrod Lincoln), 129 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
#766015 07/27/2011 1:55 PM
Does anyone know if the chrome ash tray knob designed for 47-53 trucks will work with a 1940? I guess as long as the holes are the same size and in the same spot? I was going to order the rose tan replacement for 40-46, but I think the chrome would look better.
1940 Chevy 1/2 ton, 12 volt, 350/350th
stevebolt #766045 07/27/2011 4:20 PM
I used the rose tan on mine to match the window cranks. I think chrome would look fine as well - it is kinda tucked down under the dash so you don't see it a lot.
1940 Chevy KC 1/2-Ton
Britcon #766048 07/27/2011 4:45 PM
If you look in the catalogs, the knob is a different part completely. I thought maybe the mounting posts would be in the same positions, because maybe the ash trays were the same? I'm hoping that's the case because I'd rather use the chrome.
stevebolt #766055 07/27/2011 5:16 PM
the ashtrays are totally different - this is the later one
squeeze #766073 07/27/2011 6:09 PM
Oh yeah they are, huh. Then I guess GM would have had no reason to make the knobs interchangable, since they changed the ash tray design anyway.
I'd order one anyway, just to try it but lately everything I've been ordering on a hunch that it might fit has turned out to be a waste of time and money.
I guess I could get the tan rose one and just paint it black. The chrome would have looked so cool though.
Moderated by  ndkid275, Phak1
