1 members (baldeagle), 50 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#765416 07/25/2011 4:20 PM
On my '56 gmc 270 ci six, the heat riser spring is gone and the weight is in the down position- does that mean the valve is open?
Well, my time went so quickly,
I went lickety-splitly
Out to my ol' 55.
As I pulled away slowly,
Feelin' so holy,
God knows, I was feelin' alive..... Tom Waits, Ol' 55
Look at the last few pictures at the bottom of his album, it shows several views of the heat control valve: http://www.pbase.com/dennygraham/manifolds&page=all
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
Looking from the front of the truck, rotate the weight as far counter clockwise as it will go. That is the heat off position. Turning it clockwise will put a lot of heat into your carb. I got mine freed up enough to barely move then jammed it into the off position and there she stays. A bit of choke on cold start and she's good to go.
Tiny #765704 07/26/2011 1:44 PM
Y
yar Offline
Y Offline
Dave, when I restored my '36 Chevy pickup in the early 1970s I found the same stuck heat riser valve that every one of these vehicles seems to have. Penetrating oil and tapping with a hammer helped a little but it would soon stick again. Everyone I spoke with about this situation had the same problem or worse.
It became obvious that mickey mouse approaches like oiling and tapping weren't working for anyone and I didn't expect to be the exception. Some people insist that the heat riser is unnecessary. Arguing about whether or not mechanisms should work properly is a waste of time.
Believing that the heat riser was put there for a reason and it should probably be working properly, I finally bit the bullet about 30 years ago and pulled the exhaust manifold off to do a permanent fix. I made the shaft from a piece of stainless steel bar and drilled the manifold casting for stainless steel sleeves that I tapped into the enlarged holes. The stainless steel is available as bolts in a hardware store.
It helps to have a lathe to make the bushings but the whole project can also be done with a drill press, hacksaw and file to make the flat spot on the shaft for the heat riser butterfly to attach to. That project was done in about 1980 and there has been absolutely no sticking since then.
If the details of this interest you my email is [email protected].
Ray
