0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Yesterday I found a new seat for my 48. It was out of a 50 3100. Looks new and the underside is perfect. Unfortunately, it has 2 small rips from somebody that sat on the seat with a screw driver in his pocket.
Anyone know a good way to fix these holes?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | duct tape? it is an old truck after all  otherwise get out the upholstery needle and thread and patch it with a matching fabric Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I was thinking of superglue or there is a kit at Autozone.
I was thinking it this heat that duct tape would roll up and make a mess.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes duct tape doesn't like being sat and slid on, that's why you slip it under the rip  superglue won't work unless you can get a good overlap or add a patch piece on top Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Forget duct tape, it's not even code to use on ducts! Seriously, if you have a vinyl seat with puncture wounds, I've been told that miracle vinyl patch stuff can actually work, but have not tried it myself. Let us know if you use it.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
