6 members (37 GC, klhansen, Shade Baby, Reftys49, MaxStewart, Philipj), 95 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
ive got a '46 2 ton and i would really love to get a front drive axle on it. my problems are A) i cant find any front drive axles B) i have a 2 spd rear end. any ideas any one? would it be worth the time and effort to make the conversion and would it be possible to have a 2 spd front axle as well?
welcome to the shop Jimmy - I've never heard of a 2 speed front for a 4x4, and keep in mind that the front and rear differential ratios need to be nearly identical to work .... the only way I'd think you could do it would be to find a 1T or larger 4x and swap the whole drive line in - early 4x conversions were done on big trucks for the military [scarce and more likely 6x6] or you might find a newer 4x to work with - OTOH, a 2T 4x won't be much use except for climbing walls grin
Not that I know for sure, but I would think a two speed front and rear would be impossible. I see no way to switch the two axles switch at exactly the same time. If the front is driving and one axle switches and the other doesn't there will be chunks of something scattered far and wide. That is probably why a dual axle rear is a single ratio.
1947, 1950, & 1952 Chevrolet 1/2 ton
1952 GMC 450 series Cab Over Engine
1946 Chevrolet 2 Ton
H Online: Content
Find a military 2 1/2 ton and swipe the running gear out of it. I'm pretty sure some of them had a 2-speed transfer case.
thanks for the input everyone. the rear axle is operated hydrovac and ive never shifted it while driving anyway so i wouldnt be too worried about one engaging faster than the other. another potential problem, now that ive been searching nonstop today, is that i have a pto drivin pump for a dump as well so i dont know if a transfer case would fit. and the military trucks seem to be nearly impossible to find, as if a 46 chevy isnt hard enough to find anyway :/
If you could find a front axle with the same ratios as either your rear hi or lo you could potentially run in that ratio w/all 6 axles. You would have to have a fail-safe method of ensuring that your rear cannot be in the wrong ratio with the front axle engaged. A mechanical linkage would be the only feasible method. Electric or vacuum shift would have a chance for the rear to not shift and screw things up.
You keep referring to rear axle, in the singular. Do you have a tandem rear now? If now you would need to find a tandem rear anyway to be a 6x6.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
