0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#765096 07/24/2011 2:47 PM
Yesterday I found a new seat for my 48. It was out of a 50 3100. Looks new and the underside is perfect. Unfortunately, it has 2 small rips from somebody that sat on the seat with a screw driver in his pocket.
Anyone know a good way to fix these holes?
TIA
Dennis
oldbluetruck #765105 07/24/2011 3:19 PM
duct tape? it is an old truck after all grin otherwise get out the upholstery needle and thread and patch it with a matching fabric
squeeze #765106 07/24/2011 3:21 PM
I'm a sucker for "as seen on tv" commercials. Give this one a try. Some of them actually work pretty well! You might be able to get it in your local shopping mall.
https://www.asseenontv.com/liquid-leather/detail.php?p=294673
JTKimothy #765138 07/24/2011 5:54 PM
I was thinking of superglue or there is a kit at Autozone.
I was thinking it this heat that duct tape would roll up and make a mess.
Dennis
oldbluetruck #765175 07/24/2011 8:23 PM
yes duct tape doesn't like being sat and slid on, that's why you slip it under the rip grin
superglue won't work unless you can get a good overlap or add a patch piece on top
squeeze #765189 07/24/2011 9:20 PM
Redryder pix
My Hotrod
joker #765609 07/26/2011 3:30 AM
Forget duct tape, it's not even code to use on ducts! Seriously, if you have a vinyl seat with puncture wounds, I've been told that miracle vinyl patch stuff can actually work, but have not tried it myself. Let us know if you use it.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Moderated by  ndkid275, Phak1
