6 members (Southerntruck, Tiny, HandyAndy, TUTS 59, 66flea, 1 invisible), 73 guests, and 1 robot.
Topics128,092
Posts1,056,043
Members48,433
#76456 04/18/2007 4:41 AM
I gotta 12 bolt rear in my 64 1/2 ton, and I figure this to have been a 6 cyl truck, so can anyone venture a guess as to my likely ratio back there?
#76457 04/19/2007 3:19 PM
3.73 was the factory gear ratio in the C10 trucks of '64-'66. You can also check by removing the differential cover and counting the ring gears and pinion gears and dividing the larger number by the smaller number. This will give you the correct ratio of your rearend. I hope this helps.
Tony
#76458 04/19/2007 4:25 PM
As Tony says, 3.73 was standard, rare but optional was 4.10(usually behind 3 spd O/D) & the economy option w/3.07. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#76459 04/19/2007 6:01 PM
Thanks guys,
Sorry i didn't look harder at the archives though, this one was pretty well answered already. Someone said there was a stamp on the pumpkin somewhere that would tell me. Does anyone know where the stamp usually is?
#76460 04/19/2007 6:49 PM
Usually on top of the pass axle tube near the pumpkin, tough to find after 40+ yrs but it is there,,Brian
