| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Looking for replacements for the tiny clips that hold the trim strip on the dash of a '40. They go through the dash and then you twist them with pliers so they hold it in place. Half of mine are broken. Does anyone know where to get replacements? I found these, which are listed as grill trim clips for a '46, but they look identical. http://secure.oldchevytrucks.com/TR...-CENTER-STRIP-11-req/productinfo/TRC113/ Could they be the same thing?
1940 Chevy 1/2 ton, 12 volt, 350/350th
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | The ones shown from J Carters is what I used on my 4t6 dash and on the hood strip centers. Have fun and good luck Dan | | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | The ones shown from J Carters is what I used on my 4t6 dash and on the hood strip centers. Have fun and good luck Dan Great! That's the answer I was hoping for. Thanks!
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I think the ones on my dash were flat rather than curved where they slide in, but if they fit, they fit!!! That's good to know!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | So I got the clips, they don't fit into the dash strip like I'd hoped. They're a little too wide, but I can trim them a little with the bench grinder and make them work I think.
