9 members (Peggy M, Otto Skorzeny, tclederman, Shade Baby, DadsFirstPickup, FAST55, Bucker, wilbur53, 1 invisible), 78 guests, and 4 robots.
Topics128,159
Posts1,056,900
Members48,458
My '53 GMC Series 100-22 1/2 ton has a four speed transmission, 1st is a super low granny gear. It appears this is an optional upgrade rather than the standard three speed. I need to replace some clutch parts and can't figure out what size clutch plates I need (9 1/8", 10", bigger...). And who might have an appropriate clutch kit?
Thanks in advance for your help,
Craig
1953 GMC half-ton
Riding in the Passing Lane
You pretty much have to take it out & measure it. There are many clutch options. Any parts store can supply it. Sometimes the replacement is different from the original but as long as you use the matching TO brg. it will work. Make sure its a diaphram type clutch though. You don't want a finger type.
1972 Chevy c10 Cheyenne Super
