7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible), 123 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
My 67 C/10 has the Borg Warner OD tranny from the factory. I need the kick down switch located under the carb. The switch has pins where an overmolded wiring harness snaps on. I called Fifth Ave Parts in KS. They have a switch but only one with screw type terminals. Who other than Fifth Ave carries parts for the BW OD tranny system?
hard to find any OD parts outside 5th Ave, but look in the user list for "rfs56trk" Stovebolter #6366, he does a lot of OD work .... also check out NAPA #OD6284, it's a kickdown sw, don't know the configuration
The NAPA one is a floor switch like most everyone used except Chevy. And they couldn't deliver when I needed one last year.
You might give Yesteryear Anitique Auto Parts a call. That's where I found mine. I won't guarantee that they'll have it, but it would be worth checking out.
BTW, the one I got from them was a NOS GM part, not aftermarket.
Bill Burmeister
