7 members (Otto Skorzeny, DHedrick, TexasFarmTruck, Joe H, Sedgewick, Charles in CA, crenwelge),
153
Mod | | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 24 | My 67 C/10 has the Borg Warner OD tranny from the factory. I need the kick down switch located under the carb. The switch has pins where an overmolded wiring harness snaps on. I called Fifth Ave Parts in KS. They have a switch but only one with screw type terminals. Who other than Fifth Ave carries parts for the BW OD tranny system? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hard to find any OD parts outside 5th Ave, but look in the user list for "rfs56trk" Stovebolter #6366, he does a lot of OD work .... also check out NAPA #OD6284, it's a kickdown sw, don't know the configuration
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The NAPA one is a floor switch like most everyone used except Chevy. And they couldn't deliver when I needed one last year. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might give Yesteryear Anitique Auto Parts a call. That's where I found mine. I won't guarantee that they'll have it, but it would be worth checking out. BTW, the one I got from them was a NOS GM part, not aftermarket.
Bill Burmeister | | |
