1 members (Rusty Heaps), 114 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
Installed on my 1959 gmc 1/2 ton for about 5 years. The pedal does not always return to the top. This is the under floor booster with combination valve on a disc/disc truck.
When I start the truck, I can see the pedal move about 1/2 way down, and then slowly come back up. Brake travel seems a bit much. I noticed a small drip of fluid coming from the booster last week.
So do I have a bad MC? (spent several hours bleeding the brakes today, the front reservoir was dry.)
A bad vacuum booster?
Or something else I haven't considered?
Oh yeah, I suspect a broken spring in the front part of the MC which actuates the rear brakes.
Sounds like the seal at the pushrod and the seal in the booster are bad. If you check the hose to the manifold from the booster, it'll probably be wet with brake fluid.
Bill Burmeister
Thanks Bill
Under the rubber dust boot on the booster, there was a metal cap with a felt seal that had worked it's way off the booster. That cap was preventing the pedal from returning.
I believe the excessive brake travel is the adjustment rod between the booster and the MC. I believe this rod has walked in over time increasing the free pedal travel before the MC is actuated.
