| | | Forums66 Topics128,162 Posts1,056,944 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 23 New Guy | | New Guy Joined: Jan 2011 Posts: 23 | this truck has 700-17 rims and tires can't find tires for it and coker wants a home loan for 4 tires. im looking for a cheaper alternative to them and a found these.
crager nomad 15x7 8 lug 8x6.5 bolt pattern with a 4 inch backspace and 0.00 offset just curious if this rim would work? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Those should work just fine, Wagon Wheel Cragars were made for trucks.
Are you planning to run stock width tires? Reason I ask is if you want to go with some wider tires the 7" wheel width may be a problem.
| | | | | Joined: Jan 2011 Posts: 23 New Guy | | New Guy Joined: Jan 2011 Posts: 23 | well john im hoping to keep it skinny. wide tires are a no no with no power steering
so maybe a 5x6 would work? because i can get bias LT nylon tires around 12 ply 7.00-15.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | well john im hoping to keep it skinny. wide tires are a no no with no power steering
so maybe a 5x6 would work? because i can get bias LT nylon tires around 12 ply 7.00-15. http://imageshack.us/photo/my-images/34/img00140201105101308.jpg/33X12.5x15 I run these on my C930 without p/s and do not find a problem. perhaps you are not eating your wheaties in the morning ron
| | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 |
Try Universal Tire in Hershey,PA.I bought a set of 5 made by STA (formerly McCreedy Tire).They have them in 7.50X17.
- Doug | | |
