0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#76069 04/08/2007 8:22 PM
Apprentice
Apprentice
Need to add oil in a 50 GMC with a 228. I am new to this and could not find an obvious oil fill location. Do I take off the oil breather tube and add oil there and then replace the tube?
#76070 04/08/2007 8:35 PM
Isn't there a cap on the top of the road-draft tube?
#76071 04/08/2007 9:25 PM
Junior Member
Junior Member
Hi Isn't there a oil breather on the top of the valve couver? If so screw it out and add oil.
#76072 04/09/2007 8:46 PM
Apprentice
Apprentice
don't remember anything on top of valve cover. there is a cap on top of the tube but it at least does not pull off easy because I tried and then noticed that the whole assembly raises off the engine were I see the hole into the block.
#76073 04/09/2007 8:53 PM
It doesn't pull off. Hold the road draft tube and turn the cap about an eighth of a turn counter-clockwise to remove it.
