1 members (baldeagle),
26
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | I have been trying for about one year to get the brakes fixed on my C60 truck. The truck has a hydrovac system. When I fill the resovoir it always leaks out. Saturday I noticed the boot directly behind the brake pedal is torn and brake fluid is leaking down the wall onto the floor behind the mat. This is why I could never find the leak anywhere. Is there a valve behind this that would be leaking or is it just the boot? Appreciate any help!! | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | As Joe said, you have a bad MC. There shouldn't be any fluid in the boot, it's just a dust cover. Fluid in the boot means it's leaking past the MC cup due to a bad cup or pitting in the bore. Mike B  | | | | | Joined: Nov 2010 Posts: 11 New Guy | | New Guy Joined: Nov 2010 Posts: 11 | There are rebuild kits in Canada at the NAPA stores but with mine I found that the cylinders were pitted bad and the rebuild kit only lasted for two years before I had the MC machined and re-sleeved.
Joe | | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | any suggestions on best way to remove the m/c? I assume the resovoir is separate and above the m/c which would be located below this and behind the pedal?? | | | | | Joined: Nov 2010 Posts: 11 New Guy | | New Guy Joined: Nov 2010 Posts: 11 | Sorry for such a slow reply... the best way to remove the M/C is to leave the lid on tight, and undo the three bolts or so that hold it onto the firewall and it then just pulls off the front. | | |
