4 members (Hambone, 2-Ton, Otto Skorzeny, TUTS 59), 147 guests, and 3 robots.
Topics128,084
Posts1,056,087
Members48,434
#704564 12/18/2010 9:55 PM
Like to get some feedback here on what parts would be needed for folks to start using this engine, I'll start the list with:
4200 to T-10 style bolt pattern bellhousing
4200 to T-5 style bolt pattern bellhousing
Carb intake - if so for which type carb?
Simple to use ignition box for use with the above intake? Retains the stock coils.
Distributor conversion ?
Others?
FYI Exisiting parts are: MT flywheel, rear sump oil pan, headers.
Also like to get an idea on which of the above parts hold interest...
1 Offline
The Chev 4200 guru's I talk with are at Self's Racing in Durant,OK. They have a 4200 they are developing for racing and are getting over 500 HP from it. They do all sorts of work with the engines they are developing.
Normbc9
