1 members (66flea),
93
Mod | | | Forums66 Topics128,265 Posts1,058,363 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Okay, I'm working on my '63 C20 LWB stepside, and I'm keeping her stock. So, that means keeping the granny 4 spd and 5.56 rear gears. That's right, 5.56:1. She was built for pulling. Like I tell everyone, with the 292, 4 spd, and 5.56 rear, she will pull a house off it's foundation.....slowly  So, the big question is how fast will she go on the highway. I'm thinking I will be very lucky to hit 55, but what do you guys think?
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Sep 2009 Posts: 21 New Guy | | New Guy Joined: Sep 2009 Posts: 21 | I think you are about right, maybe 5 one way or the other, | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | Not very.  | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | (revised for 5.14 gear) Assuming a 28 inch dia. tire... 4000 RPM 64.82 MPH 3500 RPM 56.72 MPH 3000 RPM 48.62 MPH 2500 RPM 40.52 MPH 2000 RPM 32.41 MPH Assuming a 30 inch dia. tire... 4000 RPM 69.46 MPH 3500 RPM 60.77 MPH 3000 RPM 52.09 MPH 2500 RPM 43.41 MPH 2000 RPM 34.73 MPH Assuming a 33 inch dia. tire... 4000 RPM 76.40 MPH 3500 RPM 66.85 MPH 3000 RPM 57.30 MPH 2500 RPM 47.75 MPH 2000 RPM 38.20 MPH Bigger diameter rear tires = faster highway speed at given rpm Bigger diameter rear tires = more clutch slipage to get the truck moving. Not a problem though with your "granny tranny". ( I am running 33" dia. tires on my truck) Above data calculated using this website: http://www.wallaceracing.com/gear-speed.phpHope that helps!  John
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have the same gearing. i cruze at 3000 rpms at about 52 to 54mph. noone else likes it at the speeds they drive and i get a lot of "one finger salutes". both are just a sign of the times i guess. | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | I ain't in no rush either! 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Thanks for all the responses, I figured the ol girl would be puttering down the road. Tony, it's got 5.56 rear gears. The rear end it has in it was an option and also has a dealer installed No-Spin locker. That is one of the reasons I am keeping this truck stock.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It should be a 4.56 or a 5.14, those were the only options. The 4.56 is a more common of the two, as it was the standard gear for the 3/4 ton.
Bill Burmeister | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I had to do some looking.... Yes, it has the 5.14's. Not sure why I had 5.56 in my head. I looked up all the info in my books to verify.
