1 members (66flea), 93 guests, and 4 robots.
Topics128,265
Posts1,058,363
Members48,485
#759169 07/02/2011 4:34 AM
Okay, I'm working on my '63 C20 LWB stepside, and I'm keeping her stock. So, that means keeping the granny 4 spd and 5.56 rear gears. That's right, 5.56:1. She was built for pulling. Like I tell everyone, with the 292, 4 spd, and 5.56 rear, she will pull a house off it's foundation.....slowly grin
So, the big question is how fast will she go on the highway. I'm thinking I will be very lucky to hit 55, but what do you guys think?
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
I think you are about right, maybe 5 one way or the other,
Quote
How fast will it go?
Not very. wink
1962 C-10 Chevy
More pix on Photobucket
ADHD and luvin' it
(revised for 5.14 gear)
Assuming a 28 inch dia. tire...
4000 RPM 64.82 MPH
3500 RPM 56.72 MPH
3000 RPM 48.62 MPH
2500 RPM 40.52 MPH
2000 RPM 32.41 MPH
Assuming a 30 inch dia. tire...
4000 RPM 69.46 MPH
3500 RPM 60.77 MPH
3000 RPM 52.09 MPH
2500 RPM 43.41 MPH
2000 RPM 34.73 MPH
Assuming a 33 inch dia. tire...
4000 RPM 76.40 MPH
3500 RPM 66.85 MPH
3000 RPM 57.30 MPH
2500 RPM 47.75 MPH
2000 RPM 38.20 MPH
Bigger diameter rear tires = faster highway speed at given rpm
Bigger diameter rear tires = more clutch slipage to get the truck moving. Not a problem though with your "granny tranny".
(I am running 33" dia. tires on my truck)
Above data calculated using this website: http://www.wallaceracing.com/gear-speed.php
Hope that helps! thumbs_up
i have the same gearing. i cruze at 3000 rpms at about 52 to 54mph. noone else likes it at the speeds they drive and i get a lot of "one finger salutes". both are just a sign of the times i guess.
I ain't in no rush either!
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
4.56:1 or 5.56:1?
Thanks for all the responses, I figured the ol girl would be puttering down the road. Tony, it's got 5.56 rear gears. The rear end it has in it was an option and also has a dealer installed No-Spin locker. That is one of the reasons I am keeping this truck stock.
It should be a 4.56 or a 5.14, those were the only options. The 4.56 is a more common of the two, as it was the standard gear for the 3/4 ton.
Bill Burmeister
I had to do some looking.... Yes, it has the 5.14's. Not sure why I had 5.56 in my head. I looked up all the info in my books to verify.
