| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 49 | I have a 55 2nd with the stock straight front axle with 5 lug disc conversion. Right now I am running 225/70r15 tires on the front. The tires are worn and I need to replace them. Is there any advantage to changing to another size tire? Can the width or the height of the tire make manual steering better or worse? If so, what do you recommend?
Thanks, Hugh
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | narrower tires work better, as skinney as you can find and the tallest, and LT's are better than car sizes
Bill | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Backspace and offset of wheels can also play an important part too, the relation of the wheel centre line to the king pins. Especially on a non power steering set-up.
A 225 width tyre is not a huge width for a truck. A 70 series profile on a 225 gives you more than a 6" sidewall which is still pretty tall.
A few years back I had an old GM Vauxhall Cresta. The P.O. had put those awful white 8 spokes that look more at home on a Baja Bug and the offset was all wrong.
I changed the wheels to a wheel better suited to the car(same width as the 8 spokes but different offset) and it was like magic,no hauling at the steering wheel to turn! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
