5 members (Wheelie, Jay R, 1955 1 Series, Napco Man, WICruiser), 136 guests, and 2 robots.
Topics128,083
Posts1,056,080
Members48,434
'51 216:
In my search for new spark plugs my research has shown the original to be AC 46-5. What I took out of the engine were AC R43. NAPA tells me they show the correct plug to be R45XLS. The R45XLS has a much longer threaded section than the R43's I took out (3/4" vs. 3/8"). Last thing I want to do is punch a hole in a piston. Is the 3/4" too long and what should I be using?
Dave
www.fallenherosdreamride.org
all give some
MY SON GAVE ALL
The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216
In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
NAPA online shows 3/8" for all plugs listed for your year. Did you get NAPA info from online or from a local store?
I have several excellent NAPA dealers who have people who can and will look into catalogs for old parts. Nonetheless, I check out parts in NAPA online before I call or visit a local NAPA store.
Maybe someone will post informaton about the longer plug being OK. I'd go with 3/8".
Riding in the Passing Lane
The long thread fits the later engines. 63 up to about 71. I would put the extended tip plug in. R45S.
1972 Chevy c10 Cheyenne Super
Thanks. I'm going to exchange the plugs for R45S
Dave
all give some
MY SON GAVE ALL
Here are a couple of poor pictures of the most commonly used AC Delco R45 plugs
being use in the AD trucks now days. Second one shows the reach of the R45 plug and
as you can clearly see, you’ve got a long way to go to reach the piston:
http://www.pbase.com/dennygraham/image/136038165
http://www.pbase.com/dennygraham/image/136038174
Here it is with a long reach plug installed. I would think that you would have one
'ell of a time getting that plug out with the threads loaded up with deposits, which is inevitable:
http://www.pbase.com/dennygraham/image/136038755
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny,
Great photos. Thanks for posting.
I ended up with the R45S. Not sure what the "S" stands for but it has a 3/8" thread length. The "xls" were 3/4".
Dave
all give some
MY SON GAVE ALL
The ‘R’ as you know Dave, indicates a resistor plug, the ‘4’ is the thread size 14mm in this case, the ‘5’ is the Heat Range and the ‘S’ is an extended tip.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
