1 members (amtrakjoe), 59 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
Hi! I'm getting ready to install my manifold, please offer any tips before I barge ahead.
The exaust is bolted to the intake just like it was when I removed it. I didn't separate the two pieces for fear of breaking the bolts. I didn't have the manifold surfaced, I'm hoping it will sit fairly square against the head without machine work.
I don't see how to reach the bolts with a torque wrench. I was planning to use a normal wrench and tighten by feel. 15 to 20 ft-lbs for the inner bolts and 25-30 ft-lbs for the inner bolts. Gaskets go on dry with the silver side towards the manifold.
Is there anything I should be aware of before getting started?
If you haven't already I would chase any bolt threads. Anti-sieze can help ease removal if necessary later. After installation if idle is rough, maybe there's a vacuum leak if surfaces don't mate tightly. Don't forget the intake alignment sleeves(rings). It's a simple bolt on. I wouldn't worry about torquing the bolts. Snug them up tight.
Drew
Thanks Drew! I didn't chase the threads because I don't have a dull tap (only sharp ones). But I did clean the threads with penetrant and compressed air. The bolts cleaned up nice on a wire wheel and I applied anti-sieze.
The gasket was very difficult to install, it was tight around the alignment sleeves. I just jammed it on anyhow, probably deforming the gasket a bit. Hopefully it seals. My gasket kit is for a 216 but the head is a 235.
The bolts I did up even and snug, but not over-tight. They can be tightened more later if they leak.
Manifold
Wrong gasket
To torque those manifold bolts, you'll need a 9/16 crowsfot adapter or box end adapter. The crowsfoot adapters should be fairly easy to find, any parts store or Sears should have them. The box adapters might be a little trickier to find, I got mine from Snap-On.
for chasing threads, you'll want a thread chaser tap and die set, rather than a dull normal tap and die. The chasers are made to clean and reshape the threads, rather than cut new ones. A dull regular tap or die may actually cause more damage. A good set of chasers, with standard 1/4 though 9/16 in NF and NC, plus metric from 6mm to 14 mm can be found for around $50 US at Sears, Snap-On, and most other places. They are a very good investment, especially if you're going to be doing your own service on vehicles.
Bill Burmeister
