1 members (klhansen),
173
Mod | | | Forums66 Topics128,080 Posts1,056,317 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22424 11/09/2001 10:21 PM | Joined: Aug 2000 Posts: 7 Member | | Member Joined: Aug 2000 Posts: 7 | Anyone have the valve gap specs/clearances for a 54 235? | | |
#22425 11/09/2001 11:58 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | intake 0.010" exhaust 0.020"
First, run engine at fast idle for 30 minutes. | | |
#22426 11/10/2001 1:53 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Tim , my 55 manual says .oo6" inlet , .o13" exhaust , motor hot(run 30mins) | | |
#22427 11/10/2001 5:11 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 |
Fred 52 3600 69 C-10
#22428 11/10/2001 6:17 PM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I was told 8 and 18 thousandths on intake and exhaust respectively. cam manufacturer recommended something slightly tighter. was told that ehaust should have more to let valves remain on seats as long as possible as the seats are the only cooling that the exhaust valves get. :confused: | | |
#22429 11/18/2001 4:20 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | O.K. who knows what is correct?
My 1954 Truck Operators Manual says: Valve clearance (hot engine) - all engines (??) intake 0.010" exhaust 0.020"
My 1954 Chevrolet Truck Shop Manual says: Adjust valve clearances as follows (hot engine): For 235 Thriftmaster 235 engine intake: 0.006 exhaust: 0.016 For 1 1/2 & 2 ton trucks(not clear if this is for the 235 Loadmaster or 261 Jobmaster engine) intake: 0.006 exhaust: 0.020 I use the settings in the shop manual.
The car settings might be different (and the 235 Blue Flame 115 might have different settings than the Blue Flame 125).
Tim | | |
#22430 11/18/2001 7:50 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | In my '50 owners manual, it says 0.006-0.008i 0.014-0.016e for 216 regular duty and .010i 0.020e heavy duty/>5000 gvwr and 235. That could be the source of confusication. It hurts the valve seats more to have them too tight than too loose.
#22431 11/23/2001 12:55 AM | Joined: Apr 2001 Posts: 39 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 39 | i set mine at 006 /0016 and it runs great
47 Chevy COE..52 TO 30
#22432 11/23/2001 2:56 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | No one has mentioned if this motor has a solid lifter&cam or a hydraulic lifter&cam!!
???So, which is it???
| | | | | Joined: Mar 2011 Posts: 17 New Guy | | New Guy Joined: Mar 2011 Posts: 17 | If it's a solid cam 6 and 16, 7 and18, pick one.hydraulics obviously will be zero, one turn (SLOWLY!)after the slack is taken out. By all means,put a brick on the gas pedal so the engine warms up- on a 235 about 5000 RPM for 20 minutes should do it, v-8's I figure about 7500 RPM and 30 minutes or until the last rod flies past your head (don't forget to count!, and main bearings don't count). Happy motoring!Follow these instructions and youll never have to worry about setting your valves agian. | | | | | Joined: Mar 2011 Posts: 17 New Guy | | New Guy Joined: Mar 2011 Posts: 17 | If it's a solid cam 6 and 16, 7 and18, pick one.hydraulics obviously will be zero, one turn (SLOWLY!)after the slack is taken out. By all means,put a brick on the gas pedal so the engine warms up- on a 235 about 5000 RPM for 20 minutes should do it, v-8's I figure about 7500 RPM and 30 minutes or until the last rod flies past your head (don't forget to count!, and main bearings don't count). Happy motoring!Follow these instructions and youll never have to worry about setting your valves agian. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | You may want to try a new act, this ones getting old.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Man J, I'm right behind ya on that!!!
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | well I don't know about the pieces flying, my dad and his brother had an old chevy with a 216 they tried to blow up in that very manner, and it ran out of gas. so they sold it to a friend who drove it for a couple of years. Also from what I have heard from some of the fellas that used to race these engines 5000 rpm wouldn't hurt them anyway. (obviously with a lot of preparation) We have a sense of humor and enjoy a joke as well as the next guy, but you need to contribute something useful as well, this site has a purpose... | | |
