1 members (frogfarmer), 116 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
#757723 06/26/2011 7:12 PM
Where is the antenna located on a 49 one ton pickup? Thanks, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
It goes on the cowl, in front of the left corner of the driver's windshield. there is a very specific location that does not interfere with the hood. There is a template that is supplied with the antenna. The correct antenna has a support bracket that attaches to the sheet metal inside.
1951 1 Ton Completed
Here is the instruction sheet and template for the reproduction version of the original-style antenna.
If you end up printing out a template, make sure that the hole is the correct size. If the process scales it wrong, you could end up with a problem.
