3 members (RoadsScholar, Gdads51, Gray_Ghost), 120 guests, and 4 robots.
Topics128,078
Posts1,056,021
Members48,433
I found 2 sm420 transmissions for sale on craigs list. Thinking that I should build a new transmission to go with the new 261 that is going into my 3800, I went over to the guys house and bought them for a good price. But darn, when I got them into the shop and set them on the bench I realized there were 2 PTO covers!
After e few minutes I realized I had purchased sm465....
I thought it felt heavy!
What I can see is that these are the 4 speeds that were in the late 60s suburban and 1 and 3/4 ton trucks... Would this be a good replacement / upgrade for the sm420?
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
Riding in the Passing Lane
The sm 465 came out in 68. It is a stronger trans, but they are harder to work on. It would make a good replacement but the hole in the bell houseing is larger. You will need a later bell houseing or its seems someone mentioned at one time to turn down the retainer. The early 465 up to 73 had the lower mounting bolts come infrom the inside of the bellhouseing. They didn't have the pad on back for a mount. You can drill out the holes if nessesary or you can use bolts & nuts if you put the 73 up in an older truck.
1972 Chevy c10 Cheyenne Super
newer is likely better in this case, but 6 of one - half dozen of the other ....
The bearing retainer of the sm465 can not be turned down to fit the 261 bellhousing. You will need to have the bellhousing bored from 4.686 inches to 5.125 inches. A later bellhousing will not bolt up to the 261, without some sort of adapter plate.
I did a bit more research and am tearing apart the "bad" one now to learn more about it.
I like that it actually uses "modern" seals rather than grooves to keep the oil in.
I have the milling ability here so opening that hole will be cake.
I'm wondering if I'll have to shorten the drive shaft as this trans is at least 2" longer than the sm420.
Thanks for all the help here!
Jeremy
More pix on Flickr
You might have to shorten the driveshaft, but I would probably put it together and see how much free movement you have first.
