7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 30 New Guy | | New Guy Joined: Dec 2006 Posts: 30 | Have a bad one and need to replace it... Question: Will a float/sending unit from a' 1963 c10 work in the 65? Pre thank you's  ...
"There's no head like Steelhead" | | | | | Joined: Jul 2008 Posts: 33 New Guy | | New Guy Joined: Jul 2008 Posts: 33 | 1960 to 1966 gas sending units should be the same for in the cab tanks.
Leon Stallings Hartsville, SC 1965 Chevy C20 LWB 1965 Chevy C10 LWB
| | | | | Joined: Dec 2006 Posts: 30 New Guy | | New Guy Joined: Dec 2006 Posts: 30 |  ...
"There's no head like Steelhead" | | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | They are the same. I repaired mine. There is a flat copper band that goes from the float assembly to the connector for the gage. Mine was broken there and I just soldered it back together, works like new. Chris
| | | | | Joined: May 2009 Posts: 47 New Guy | | New Guy Joined: May 2009 Posts: 47 | your float will work but sending units from a 63 and a 66 have different ohm readings | | | | | Joined: Jun 2011 Posts: 8 New Guy | | New Guy Joined: Jun 2011 Posts: 8 | Mine is bad too. I'll be troubleshooting this soon. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | '60-'66 Chevy truck sending units are all 0-30 ohms.
