| | | Forums66 Topics128,055 Posts1,055,785 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | I have a 1940 Chevy WB-Series 1-1/2 Ton truck my grandfather bought brand new. It has always been stored inside and has the original paint on the truck. It is in remarkably good shape, but is slightly dull. I am wanting to polish/wax the truck, but want to make sure I am not using something that will harm the original paint surface. Any help will be appreciated. | | | | | Joined: Jun 2011 Posts: 6 New Guy | | New Guy Joined: Jun 2011 Posts: 6 | It all depends on the paint. Chances are that your paint is really thin so a buffer is more that likely out of the question. If it was mine I would do a three stage process. Start with a good cleaner wax, this will help to remove all the junk that sticks to the paint (if you rub your hand across the surface lightly you will feel little bumps, etc.) and it will give you a good base for your next step which would be a polish. The polish will give you the shine back. Then lastly I would go over the whole truck again with a carnauba wax. This will seal the paint and help protect all of the work you just put into your truck. If it was me I would put another coat of the carnauba wax on a couple weeks later to help build up the protection. Hope this helps. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | In addition to Redwood7's process, I'd add these initial steps before waxing....
1.) get some professional grade wax and grease remover & wipe off any previous "stuff" that may still be on the surface. Do it twice to make sure. THis is a solvent that is used to final prep a car for paint. This will only take minutes and dries fast.
2.) Invest in some 3M "PERFECT-IT" OR FINESSE-IT" (not cheap, but good stuff) These finishing products can work wonders on old lacquer, in bringing back a shinier surface. Do it by hand; section at a time.
Then go ahead and wax her down.....!
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Just wondering guys....would a clay bar help clean up any oxidation/impurities before waxing or would that be too aggressive,considering the age/thickness of the paint? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I'd use 3M handglaze, and a good carnuba wax. And cover it with painters plastic like from home depot leave it loose and not to the floor, cause of moisture. Don't have it so theres a breeze blowing it either, I'm sure any movement could in time abraid it in area's. I don't like any cloth on because it will hold moisture. But wax will keep moisture out of the paint.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I would not do a clay bar.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have a 1940 Chevy WB-Series 1-1/2 Ton truck my grandfather bought brand new. It has always been stored inside and has the original paint on the truck. It is in remarkably good shape, but is slightly dull. I am wanting to polish/wax the truck, but want to make sure I am not using something that will harm the original paint surface. Any help will be appreciated. The dull paint is oxidized paint. Anything you do to shine it will remove that paint. I'm not saying to not do it just be aware that every time you "polish" the paint or use a wax with a built in "cleaner" you remove some of it. Eventually you'll work through the paint so I'd not "polish" it regularly. Other than that most anything you put on it in the way of a wax or sealer won't hurt the finish. It's so neat that the truck has stayed in your family all these years. IMHO a slightly faded finish on an original truck is a badge of honor, indicating it's been used & loved all those years.
