1 members (Otto Skorzeny),
54
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 15 New Guy | | New Guy Joined: May 2011 Posts: 15 | My 1950 Chevy PU driver's door won't lock. This is the door that is locked without a key (other door with key works fine). Upon closing the door tight the interior handle is supposed to be pushed into a locking position which engages the lock in the door. However, the outside handle disengages the interior handle and it opens, so it isn't locking.
I took the door panel off and looked for anything obvious and looked in the shop manual for help with this and it is of no use. Where do I go from here?
1950 Chevy 3100 5-Window 1946 Chevy Panel 3/4 Ton
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | The driver's side door can only be locked from the inside. It's kind of like the problem of having to hold the button down when shutting the door to get a car door to lock. Unfortunately this also means you have to exit the passenger side for it to remain locked.
Does anyone know whether you can adapt the driver's door latch to operate with a key lock like the passenger side?
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: May 2011 Posts: 15 New Guy | | New Guy Joined: May 2011 Posts: 15 | That is a good idea, it would seem like a possibility to do. A good question to put out to the mobs to see if it has ever been done. However, I wouldn't want to do it on an existing restored truck and make a mess of a good door and paint job. If I was restoring this truck from scratch and it was all apart that would be a good time to try some thing like that. I just want to get this door to lock, and I'm trying to find out which component in the door is preventing it from locking. I think it is this part: http://www.chevsofthe40s.com/detail/10853/Chevrolet_DOOR_LATCH_ASSEMBLY_LEFT.html and I will probably have to just bite the bullet and buy it and hope it solves the problem.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, that is the part that contains the internal locking mechanism. Have you inspected yours? There will be a mechanical stop that should keep the outside handle from turning when the mechanism is in the lock position. You may have a broken tab. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | My '49 did pretty much the same thing. These old mechanisms are always worn out, think how many zillion times they have been used! Go with a new latch and get on the NEXT problem!!!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | still curious as well about adding a drivers side door key lock...I realize i'm probly comparing apples to oranges, but i'm considering using the Altman easy latches and since you cant lock those from the inside and I only have a keylock on the passenger was curious if it was possible to add a key lock on that side as well........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
