4 members (Otto Skorzeny, Jon G, JacobU66, 1955 1 Series), 69 guests, and 1 robot.
Topics128,026
Posts1,055,399
Members48,422
#755787 06/19/2011 3:16 PM
I just finished laying on the last coat of base-coat. I used a turbine HVLP. I don't particularly like the amount of orange peel in places, even though I sprayed the last two coats fairly wet. Should I try to wet sand the base-coat before spraying on the clear-coats, or wait after the clear-coat is applied? The paint is Omni PPG.
Thanks, Don.
Donsz #755797 06/19/2011 4:14 PM
Back when I was doing a lot of base/clear painting, the procedure was to spray the clear over the base without sanding if there was less than a 4-hour time span between applying the base and following up with the clear. After 4 hours, it was necessary to scuff-sand the base coat. If you've got orange peel, I'd suggest wet-sanding the orange peel areas, and scuff-sanding the whole thing. Do a very good wipedown with a tack rag to remove any sanding dust.
Thanks Jerry, I'm going ahead and clear-coat without sanding. After fixing a few spots I certainly can see that it makes sense to not sand the base-coat if possible.
Don
Donsz #755965 06/20/2011 2:54 AM
something I've done when I've had dry spots, or light orange peel in the base coat, is to lay down at least 2 heavy coats of clear, come back the next day and wet sand the clear smooth. Then go back and lay down one more even wet coat of clear.
Keith
If it were easy they'd have grade schoolers doing it!
Pakrat48 #756060 06/20/2011 2:06 PM
Thanks Keith, I think I will need to do that.
