| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 8 New Guy | | New Guy Joined: Apr 2011 Posts: 8 | I need some help here. I've put a SBC 350 into my 54. I'm trying to figure out the best way to hook up the throttle linkage to my carb while keeping my pedal that goes through the floor. Has any of you fabricated something that worked? Or is there some place I can look to find a dealer that has one for this purpose? | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Truck Shop, Brothers, and probably several other aftermarket suppliers sell a reproduction V-8 throttle linkage for TF (55-59) trucks. It should also fit the pedal configuration on a 54-55 1st series. Fred
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Lokar makes a a couple of bulletproof throttle linkage kits.
I've used three of them on engine swap projects.
mike
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Locar Throttle Out of a 96 Chevy pickup.
~Jim
| | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Hi From england I have a 54 with v8 I made my linkage out of 2 x 1/4" rod joints 1/4" threaded rod with a 1/4" alu sleeve, then i just made some quick nylon bushes for carb end works a treat http://www.flickr.com/photos/54chevy/
if it ain't greasy it ain't diddly
| | | | | Joined: Apr 2011 Posts: 8 New Guy | | New Guy Joined: Apr 2011 Posts: 8 | Thanks Big Chevy for the 96 throttle hook-up. I actually have a pedal that's similiar to that one that came out of a 88 Chevy Van that I should be able to make brackets for. Not sure why I didn't think of that guess I was just standing to close to the project as the say to see good options lol. | | |
